Message No. 22493, Started by Great Wall Machinery on 04/26/16
Product Introduction
The vertical roller mill has been widely used and promoted in the electric power, metallurgy, chemical industry,
non-metal industry because the overall efficiency attributed to energy-saving and low consumption is becoming
more and more evident in the cement industry.
GRM series vertical roller mill is developed with the features of high efficiency, energy-saving and environmental
protection which is achieved after exchanging ideas with senior experts from home and abroad and making
improvements based on same sector experience in the past years.
GRMC series typically designed to process materials in medium hardness, like soft coal or bituminous coal.
GRMK series is mainly used to grind cement clinker into fine powder during cement production,This cement mill widely used in the grinding of raw cement, slag, cement clinker, raw coal and other raw materials.
GRMS series GGBS vertical roller mill is the equipment to grind Ground Granulated Blast furnace Slag (GGBS),Nickel Slag, Manganese slag and other ore slag into small particles.
Applied material:
Barite, calcite, feldspar, talc, marble, limestone, dolomite, fluorite,ect.
limestone.jpg Gypsum stone.jpg dry mortor.jpg coal fluorite.jpg rock.jpg slag.jpg talc.jpg
GGBS production line, coal powder production line and other processing industry related to metal and non-metal mine. grinding raw meal, clinker, Ground Granulated Blast Furnace Slag, iron ore, limestone, coal powder, coke powder, coal gangue, fly ash, volcanic ash, gypsum, calcite, pyrophyllite, quartz, clay, sandstone, bauxite and other processing industry related to metal and non-metal mine.
Structure of vertical Roller mill:
1) The combined classifier improves the powder selection efficiency.
2) It is not necessary to distribute material on the grinding plate before start-up. The roller can be lifted up and down automatically and start without load.
3) It is well sealed by welded arc plate and structure is simple and reliable
4) With the help of roller turning device, it is easily to turn the roller out for maintenance.
5) Both sides of roller sleeve can be used so that the service life of refractory material is extended.
6) Grinding roller limit device can ensure a certain space between roller and grinding table, which avoids the direct friction and collision between roller and grinding table and enhances safety
7) The grinding roller is driven by spinning grinding table. Pressure filling and adjustment and roller lifting can be remotely controlled without operator on-site.
8) The roller bearing is circularly lubricated by thin oil to enable it to work under low temperature and clean grease so that the service life is extended
Working Principle of vertical roller mill:vertical roller mill work.jpg
Material through the feed tube fell on the center of grinding plate, centrifugal force generated from the rotation of grinding plate uniformly scatters and flattens the materials outwards the surrounding area of grinding plate, to forms a certain thick layer of materials bed, the material was crushed by number of rollers at the same time. Driven by the continuous centrifugal force to keep the materials moving to the outer edge of the grinding plate, the materials off the grinding plate rising with the hot air which enter from wind ring into the mill, through the mill shell into the middle of the separator, in this course materials and hot gas do a fully heat exchange, and the water quickly evaporates. Separator controls the output size of finished product, greater than the specified size are separated and fall back to the plate, while meet the fineness requirements are brought through the separator into the finished product warehouse.
