Message No. 22667, Started by marcepinc on 12/28/17
Overview:
  • Most facility managers, engineers, maintenance and construction personnel now know that Corrosion Under Insulation (CUI) exists and left to its own devices, can cause serious problems and even catastrophic consequences.
  • It is also widely known that the results of CUI are costly. How costly? That is harder to define. Most studies on the topic involve all forms of corrosion and their associated costs without providing the individual cost of corrosion related to insulation.
  • What is clear, however, is that the cost of corrosion in the World continues to increase. A study completed in 2011 by a research team of corrosion specialists enlisted by Congress titled, "Corrosion Costs and Preventative Strategies in the World" reported the direct cost of corrosion to be $276 billion per year, with that number potentially doubling when indirect costs are also considered.
  • Additional factors encourage CUI: the environment, insulation design and specifications, installation craftsmanship and maintenance. Let's examine what can be done to reduce the risks.
Abstract:
  • Out of various corrosion phenomenon, the corrosion occurring on insulated piping/ equipment at any facility is particularly difficult to track & prevent. As a global issue, CUI (Corrosion Under Insulation) may directly contribute to health, safety, and environmental (HSE) issues, lost production and increased maintenance costs.
  • CUI, therefore, needs to be combated and tamed eg. brought under control through systematic efforts. Historically, industry data shows that approximately 60% of pipe leaks are caused by CUI. Studies also show that the age of the piping system when the CUI leak occurred is bi-modal.
  • One leak population mean is found in pipes with 16 to 20 years of service life and a second population means is in piping with the service lifeof greater than 26 years. Such data needs to be used while developing strategies for CUI detection and mitigation. New plants under construction must take cognizance of leaning from CUI incidents and shall use specifications on Painting, Insulation which already incorporate this leaning.
Benefits:
  • Obtain awareness of a major corrosion mechanism that affects insulated piping/ equipment used in process industries
  • Understand the primary parameters that influence the rate of degradation, design considerations for piping/ equipment
  • Understand how to develop strategies for the detection of CUI
  • Understand CUI Mitigation - Industry Practices
  • Obtain information on all engineering disciplines that are associated with the design, inspection, and maintenance of insulated piping/ equipment including information on the types of insulation, external weather protection, and protective coatings currently in use
USP:
  • The course content will cover why CUI has become a major problem in today's context and also cover various corrosion mechanisms which affect the insulated piping/ equipment and the major parameters which influence the rate of degradation.
  • The course will cover various NDE methods available and successfully used to detect CUI. The participant will also learn the strategies for defining the scope of work for detecting CUI based on RBI (Risk Based Inspection) approach.
  • The NACE RP 0198 and API RP 583 will be discussed in detail and so also the leaning from various published case studies on CUI.
Follow-up Messages (1)
I want you to thank for your time of this wonderful read!!! I definately en...
No. 22844, Posted by funnyjokes on 01/18/19, 01:26 PST.
Copyright © 2019 eFunda, Inc.
