Message No. 24039, Started by adhirath on 10/10/19
The decline in sales for the auto industry has been pronounced and unprecedented.  While many point to short and medium factors, such as government policies and the non-availability of financing, the truth remains that most auto manufacturers remain woefully unprepared for the paradigm shift that is in the offing.
Electric vehicles are an inevitable mainstay of the future auto market both because of their economic and environmental impact. Thus far, fossil fuel-run vehicles have enjoyed the economic advantage, because EVs were both expensive to buy and had limited range and power. In addition to this, the limited infrastructure surrounding EVs meant that it was a hassle to own one, unless one was very inclined to shun fossil fuels. But as the technology has advanced, both these factors seem to be becoming less pronounced. Thanks to increased scale and large bets taken by the leaders in the EV space, the upfront costs of owning an EV have lowered significantly. In addition to this, continual improvements in the battery management systems have allowed the range to be increased to the point where a single charge may last over a week for someone doing only 30-40 kilometres a day. Further, government support for the industry has meant that the infrastructure has also moved ahead at a good pace. Many buildings – even in India – have mandatory EV charging points in all the parking spaces. Convenience-wise, this is even better than having to go to a fuel station once a week to fill up your tank with petrol or diesel!
Much of the technology of electric vehicles depends on high efficiency and a good strength to weight ratio. In such an endeavour, lightweight materials become essential. Polymers have long been known to provide long term performance and efficiency gains to any system. A rule of thumb in the auto industry has been that for a 10% reduction in weight, the fuel efficiency of the vehicle improves by 5%. For this reason, the quantum of polymers has increased from around 8Kgs to over 150Kgs over the last 40-50 years.
The effectiveness of polymers in automotive applications has always been known. As polymer science has evolved, the range of application has also broadened. Polymers such as PEEK, PTFE, PEI (Ultem) and PI (Kapton) have exhibited tremendous resistance to heat, such that there seems a little argument for using metals (which would be at least 2-3 times heavier) in areas where these polymers can be used.
As electric vehicles gain in importance, we look at some of the areas in which polymers are especially useful in EVs.
1. Sensor shields and enclosures
The use of sensors is essential in ensuring safety. As autonomous vehicles see a rise in adoption, sensors will become possibly the single most important component set within a vehicle.
Polymer shields and connectors are important because unlike metals, they remain neutral to the signals and waves being sent and received by the sensors. PTFE and PEEK are already used extensively as Radomes in antennae. As the number of sensors in the vehicle grows, it is even more essential to ensure that there is no disruption to performance, in the event that all sensors are working at once. Polymers are unique in being able to offer protection from weather, heat, and additionally, do not interfere in any way with the signals.
2. Brackets
Brackets made from polymers are useful as they hold together other components and ensure that they do not get damaged during operation. Some of these components may generate heat, so the polymer would need to withstand this as well. Brackets made from Nylon have been used as replacements for metal even in conventional vehicles, as they offer a significant weight reduction and can be moulded to suit the exact shape of the component set that they are housing. Further, in the event that a component does come slightly loose, the potential noise from the rattling is minimised significantly when a polymer is involved.
3. Insulation
Much in an electric vehicle rides on the efficiency of the battery and the use of stored power. Anything that helps minimise the leakage of current from the system aids in improving the battery life and consequently the distance that can be traversed on a single charge. Materials like PTFE and Polyimide have proven highly effective as insulators in high-voltage-high-temperature applications.
4. EV charging stations
Electric Vehicles are gaining traction over traditional fuel powered vehicles. As their demand and prevalence grows, so too would the infrastructure needed to ensure that they can function smoothly. Investments in EV charging stations have increased significantly and new housing developments are increasingly required to ensure that there are charging stations for all parking slots.
As a superior insulation material, PTFE has been found effective in EV charging stations. PTFE insulation blocks can be used to improve the charging efficiency and ensure that there is minimal leakage of current.
5. Battery separators
One of the key factors with electric vehicles is that battery storage needs to be both ample and efficient. Both PTFE and PE (polyethylene) are seen as effective battery separators. These separators provide internal insulation to the battery, preventing the batteries from discharging when idle. Although PE separators are effective in most application, high-voltage applications need PTFE films, which possess higher breakdown voltage strengths and can remain effective over a much longer time period.
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Lookinf for Teflon Tube Manufacturers? We manufacture and supply Teflon tubes that are used in Industrial, agricultural and many other domestic applications. Polyfluoro produces best quality Teflon tubes and these products are made available in domestic and international markets. These tubes are well known for their unique properties and comes with standard as well as customizable sizes.
Copyright © 2020 eFunda, Inc.
