Quality Magazine
Techniques to improve quality on the shop floor and in manufacturing planning.
Chemical Engineering
The industry gateway for chemical engineering and plant operations.
Autonomous Vehicle Engineering
The No. 1 media source for those developing the next generation mobility solutions.
Salary Expectation
8 things to know about the interview question "What's your salary expectation"?
more free magazines
Message No. 26001, Started by lucaszito on 05/13/21
Hi all,
This is my very first message on this forum.
I am building a machine for a friend who works with cardboard pulp, he is also a performance artist and would like a machine where 2 or 3 performers can activate the machine by hand with pulleys and wheels, and shred the pieces of cardboard that are soaking in a container filled with water. There is 4 pulleys in total and the last driven pulley is attached to a shaft with blades on it, this whole assembly constitutes the shredding mechanism.
Currently the artist is shredding the cardboard with a hand drill on which is attached some very small DIY blades. The drill runs for about 3000 RPM and generates 550W of power for 30 minutes, and he manages to get the consistency he wants.
In my idea of his machine 2 performers would spin a horizontal wheel bar of 2 meter(6.56168 feet) diameter at about 5 to 15 RPM and that wheel bar is attached to a pulley which is driving a 1:5 pulley, that 1:5 pulley is attached to a 1:1 pulley which drives another 1:5 pulley. Since the blade that will be made for this machine is about 12 times bigger than the original blade he was using, I am not sure that we need as many RPM as the drill gives. But I am not very sure either. Anyhow, I thought that just a little less RPM than the drill would do the trick, maybe 5000 if that is even doable. All pulleys will be made of wood and the wheel bar will be in steel tubes.
However it is my very first time working with pulleys and ratio and I lack experience in safety, in feasibility and in physics.
I do not know how to obtain the RPM I want for the rotating blade while having a decent of size for the whole machine. I have attached some pictures that give you guys dimensions and other drawings to see the machine better. Obviously the pulleys will not be floating, I just havent thought about the structure yet, I wanted to have your opinion first.
I am wondering if such a system will output the results I want, if it is durable and safe.
For the performance, the artist really wants a system like this one (...for aesthetical reasons...) with 2 or 3 performers turning the big wheel bar. This video shows a bit the effect I would like to achieve, a first pulley greedy in torque that outputs a driven pulley with a multiplied speed. The goal is really to have the performers sweat while operating the device.
The running time would be less than 5 minutes as it really takes little time for the cardboard to be shredded into pulp.
My question would be, how is it possible to make the device happen while keeping a system with a horizontal big wheel bar ? What needs to change or to be ?
Also a plan B would be to use stationary bicycles with lower RPM but I don't really know how to gear all that with a low budget...
Thank you very much for your help !
Lucas
Glossary
